Why is wire and bus bar ampacity different?
  • Power Distribution IEC
  • Why is wire and bus bar ampacity different?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
kenamm
kenamm
Cadet
Posted: ‎2024-10-25 02:18 PM . Last Modified: ‎2024-11-22 04:25 AM
965
I saw a mechanical design suggestion that when dimensioning copper bus bars then should be considered 2 amps for mm2. But when using wires you can use even a 1 mm2 wire for much higher current. Is the suggestion for bus bars not correct or can someone explain why is there different ampacity for wire and bus bar that have equal area?
omegle xender
  • Power Distribution Software
Genghiz
Captain
Posted: ‎2024-10-29 01:50 AM
Hello Ken,
In a low voltage electrical installation, the busbars are more preferred than the cable due to the following reasons.
  • They are easier to install.
  • The tap-off at the busbar is convenient than the cables.
  • The load distribution is easier.
There is a detailed explanation is here.
Team - Ecodial Expert Support
  • ecodial
Genghiz
Captain
Hello Ken,
  • ecodial
