Power Design Simulation Software?
  • Power Distribution IEC
  • Power Design Simulation Software?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
nivaar
nivaar
Cadet
Posted: ‎2024-10-24 12:25 AM . Last Modified: ‎2024-11-22 04:25 AM
1315
For our senior design project we had to design a power system to run a container farming system. We had to determine # of breakers, breaker size, loads etc and make sure everything will operate correctly. Is there a free/student trial software out there that we can put our wiring diagram into that will calculate breaker size, cable size etc to compare to our hand calculated values? I will put a section of our wiring diagram in the comments for reference. Thanks!
vshare
  • Power Distribution Software
Genghiz
Captain
Posted: ‎2024-10-24 11:29 PM
Hello
Thanks for your interest in electrical network design.
The “EcoStruxure Power Design - Ecodial INT” version is free download, and you can design your “low voltage electrical distribution network.”
After the calculation of the project, you will be able get the following results.
  • The size of the source (rating of HV/LV transformer) required to supply your system.
  • The prospective short circuit current calculation of the network.
  • The size and setting of the circuit breakers.
  • The calculation of voltage drops for the given cable length.
  • The optimum cross-sectional size of the cable conductors.
If you need further clarifications, please feel free to come back.
Thanks & Regards,
Team – Ecodial Expert Support
  • ecodial
Genghiz
Captain
Hello
Thanks & Regards,
  • ecodial
