Why NSX-HB1 is mandatory used?
  • Power Distribution IEC
  • Why NSX-HB1 is mandatory used?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Design – Ecodial
yangchi-schneiderChina
Crewman yangchi-schneiderChina Crewman
Crewman
Posted: ‎2022-01-17 09:50 PM . Last Modified: ‎2024-11-22 04:25 AM
1276
Dear All:
I have a case. Please see the picture below. It is allowed to use NSX-L type for distribution load protection. Why dose NSX-HB1 type is mandatory used for motor load under the same transformer? the system voltage is 500V. If you need the original file please let me know. chi.yang@se.com
Thanks a lot in advance.
  • Power Distribution Software
Genghiz
Captain
Posted: ‎2022-01-18 03:06 AM
Dear Chi,
Thanks for the given project file for the analysis.
For your information, the selection of ‘motor starter(s) and the possible protection device(s)’ are defined as a coordination, by the line of business. Ecodial is making the selection based on the same.
For the network voltage ; 500 volts
For the motor ratings of ; 22 kW or 30 kW
For the startup type; DOL type
For the thermal Protection Type, as 'integrated or separated', and
based on the selection of coordination; there are only a few possible solutions available.
Type 1
Type 2
GV3L 40
GV3L 50
GV3P 40
GV3P 50
NSX 100*  MA 50 * Micrologic 2.2-M 50A *  Micrologic 6.2 E-M 50A
GV3L 40
GV3L 50
GV3P 40
GV3P 50
NSX 100 HB1  MA50 * Micrologic 2.2-M 50A *  Micrologic 6.2 E-M 50A
NSX 100 HB2  MA50 * Micrologic 2.2-M 50A *  Micrologic 6.2 E-M 50A
So, You will be getting the result from one this possible solution.
Thanks & Regards,
Ecodial Expert Support
Genghiz
Captain
Dear Chi,
Type 1
Type 2
GV3L 40
GV3L 50
GV3P 40
GV3P 50
GV3L 40
GV3L 50
GV3P 40
GV3P 50
Thanks & Regards,
Genghiz
Captain
Posted: ‎2022-01-18 03:11 AM
Dear Chi,
To comment on the image, enclosed by you.
There is no relationship (Or an influence) between the 'protection device' proposed for the load circuits over the motor circuits.
Thanks & Regards,
