Simplified reference electrical power distribution network configuration for a data center; by using Ecodial
  • Power Distribution IEC
  • Simplified reference electrical power distribution network configuration for a data center; by using Ecodial
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Genghiz
Captain
Posted: ‎2020-11-25 12:11 AM . Last Modified: ‎2024-11-22 04:25 AM
4
3168
Introduction :
The data center 'architecture model' is considered as a reference to understand the 'electrical equipment's and their characteristics in detail. However the 'electrical distribution' model network needs to be prepared then a design software is needed to do so.
Architectural Model :
The enclosed image shows the 'main distribution board' of the data center.
Solution :
Here by considering the EcoStruxure Power Design - Ecodial INT version, we have prepared a sample project. This will present the basic representation of the electrical distribution network of a data center.
Project File :
Here is the link to download the Ecodial Project File
Points to be considered under the Ecodial Project :
  • The operating modes are considered to study the different operating conditions.
  • The HLLV transformer ratings is consider for it's Maximum (that is 3150 kVA), where as expectation was 3000 kVA
  • The LV Generator is represented in 2 numbers in parallel to meet the expected representation of 2500 kVA.
  • If required; the detailed consumption pattern (open and close) of the feeder needs to be considered under the operating modes.
Data Center_Project Model_EcodialData Center_Project Model_Ecodial
  • Power Distribution Software
Genghiz
Captain
Posted: ‎2020-12-01 12:03 AM
Hello Jamillah,
Thanks for your comment. As requested, an option download the relevant "Ecodial Project File" is added to the above article.
Thank you.
Replies 4
Posted: ‎2020-11-25 08:40 PM
hi Genghiz,
This is very nice. please share the ecodial project file if possible.
thanks,
Jamillah
Genghiz
Captain
Hello Jamillah,
Thank you.
Posted: ‎2021-03-05 12:36 AM
Nice work Genghiz, Can you please update the link? Seems the file is not longer available.
Genghiz
Captain
Posted: ‎2021-03-07 09:24 PM
Thanks for your comments.
The link to download the file is updated, and I hope you should be able to access the file now.
