EcoStruxure Power Design - Ecodial INT 4.9.5
  • Power Distribution IEC
  • EcoStruxure Power Design - Ecodial INT 4.9.5
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Genghiz
Captain
Posted: ‎2021-02-15 09:42 PM . Last Modified: ‎2024-11-22 04:25 AM
6
4237
Following are the offers integrated and made available at the "EcoStruxure Power Design - Ecodial INT 4.9.5" version of the application.
Other Offers :
  • Acti 9 iK60N breakers – B & C Curves, upto 63A
  • iDPN.N.Arc
Easy series Offer integration
CIRCUIT BREAKER - EasyPact™ CVS Breaker:
  • CVS100N, 160N, 250N with MA & TMD
  • CVS160 & 250 (B, F, N) with TM-G
CIRCUIT BREAKER- EasyPact™ MVS Breaker:
  • MVS06C, MVS08C, MVS10C, MVS12C and MVS16C with 9 Trip units (ET2I, ETA2I, ETV2I, ET5S, ETA5S, ET6G, ETA6G, ETV6G)
CIRCUIT BREAKER - EasyPact™ EZC:
  • EZC630N & H, TM-fixed
SWITCHES:
  • CVS400NA & CVS630NA
  • MVS 06CA, MVS08CA, MVS10CA, MVS12CA, MVS16CA
  • MVS 08NA, MVS10NA, MVS12NA, MVS16NA, MVS20NA, MVS25NA, MVS32NA, MVS40NA
  • MVS 08HA, MVS10HA, MVS12HA, MVS16HA, MVS20HA, MVS25HA, MVS32HA, MVS40HA
  • Power Distribution Software
Replies 6
SergiyZolotarev
Ensign SergiyZolotarev Ensign
Ensign
Posted: ‎2021-02-16 01:46 AM
@Genghiz hello
For which countries is this version available?
Where can I download EcoStruxure Power Design - Ecodial INT 4.9.5?
Thanks in advance
Posted: ‎2021-02-16 01:50 AM
This is the international version and applicable where IEC standards are followed. You can download the software here
Arjun
SergiyZolotarev
Ensign
Posted: ‎2021-02-16 01:56 AM
@Anonymous user  thanks for the source
searching the global site gave me only this result
dkpElect
Crewman dkpElect
Crewman
Posted: ‎2021-06-09 06:59 AM
what about use of single core cables 630 to 1000 sq.mm in ECODIAL for Transformer LV side to Main LV panel which is a  prevalent practice in middle east? Currently this feature is not available. Lack of this feature is giving wrong results to us engineers in Gulf. How about adding this feature?
Karthikeyan1
Lieutenant JG Karthikeyan1 Lieutenant JG
Lieutenant JG
Posted: ‎2021-06-09 10:34 PM
Hi @dkpElect
Thanks for your query.
In the latest International V4.9.5 version. This feature is already added. Now the user will be able to select the required cable cross-sectional area up to 1000sq.mm and Ecodial will be able to size the optimum cable CSA.
Here I attached the screenshot of your reference.
In this example, I have selected 1000sq.mm as the max permissible CSA. The application is proposing the best-suited cable CSA based on the transformer power.
You can download the latest International version by using this link. EcoStruxure Power Design - Ecodial
dkpElect
Crewman dkpElect
Crewman
Posted: ‎2021-06-26 05:20 AM
Noted. Thanks for the update.
However, it is noticed that, for 3x1000 sq.mm as per phase conductor , the PE conductor also is sized as 1000 Sq.mm  ( for both TT and TN-S system) whereas standard maximum size normally used is 300 sq.mm. Whether we adopt 50% of phase conductor rule or adiabatic equation, I don't think 1000 sq.mm would be required.
I checked with another similar software from SIEMENS and the result is 300 sq.mm for PE.(see image attached).
Any clarification would be highly appreciated .
Best Regards,
Dinesh
