Posted: 2024-06-25 01:56 AM . Last Modified: 2024-11-22 04:25 AM
Selectivity check is not working. Both Power Design (5.20) and ECT show selectivity to MTZ even it's clearly seen on tripping curves they are not. For other breakers, I did not even check because the feeders are already wrong.
Posted: 2024-07-08 05:55 AM
When an upstream device is set with a value (which is lower than) the downstream device rating; then logically the application should not verify the "selectivity between these devices."
Either; it should say
This has been informed to the product development to consider this logic fix/improvement as soon as possible to get a fool proof selectivity study for the devices.
Thanks for keeping us informed on the same.
Team - Ecodial Expert Support
Posted: 2024-07-03 05:03 AM . Last Modified: 2024-07-03 05:04 AM
Hello Arto,
Thaks for reaching this forum.
Can you please kindly provide us some additional information about the problem that you are explaining.
kindly please enclose a snapshot of the application Or a project file for the further analysis.
Thanks & regards,
Team - Ecodial Expert Support.
Posted: 2024-07-04 10:04 PM
The team is looking at this, we revert you with the comments.
