NW 50 H1 Breaker not closing.
  • Power Distribution IEC
  • NW 50 H1 Breaker not closing.
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
J_Travostino
Sisko J_Travostino Sisko
70
S-W
Commander S-W Commander
67
alungalsanthosh
alungalsanthosh
Cadet
Posted: ‎2022-07-04 11:52 PM . Last Modified: ‎2022-07-07 11:34 PM
1
1228
Breaker not closing, Motor charged but indication showing un charge, charging motor circuit is open, charging handle not engaged. If press the close button by manual no action. Please advise the further trouble shooting, and how to release the spring charging and reset the mechanism.
  • Products
Christian_Bach
Lt. Commander Christian_Bach Lt. Commander
Lt. Commander
Posted: ‎2022-07-07 05:08 AM . Last Modified: ‎2022-07-08 12:15 AM
Hello @alungalsanthosh ,
A few questions :
What is exactly the state of the front indicator ?
- Discharged
- Charged "Not OK"
- Charged OK
What happens if you try charging the mechanism by handle ?
Alternately, did you investigate the following points :
- interlocking ?
- MN shunt trip coil not powered ?
- Trip indicator not resetted ?
Christian
Christian_Bach
Lt. Commander
A few questions :
- Discharged
- Charged "Not OK"
- Charged OK
- interlocking ?
Christian
