MV Switchgear Partial Discharge Monitoring system
  • Power Distribution IEC
  • MV Switchgear Partial Discharge Monitoring system
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
faisalamir
Lieutenant faisalamir Lieutenant
Lieutenant
Posted: ‎2023-01-23 11:01 PM . Last Modified: ‎2023-03-01 06:59 AM
2793
Dear Colleagues,
I would like to ask your advice if there is any reference or standard for the system of partial discharge monitoring of MV switchgear using the Schneider solution with a coupling capacitor in the bushings
Any advice would be greatly appreciated
Thank you,
Faisal
  • Medium Voltage
faisalamir
Lieutenant
Posted: ‎2023-01-30 08:31 PM
In response to HelvinHermanT
Hi Pak Helvin,
Thanks for your prompt response.
Let me clarify that our client Technip Energies and British Petroleum need our solution for online continuous partial discharge monitoring and possible integration into existing SCADA
I have presented to the customer that SE can provide the solution by using partners from "ndb" technologies or by using our original SE solution with coupling capacitor inside the bushings natively equipping the switchboard that will be launched in the 1st quarter of this year
Faisal
HelvinHermanT
Admiral HelvinHermanT Admiral
Admiral
Posted: ‎2023-01-30 05:32 AM
2753
Hi Pak,
Schneider Field Services used to have an offer called "ProCorona" which can detect the presence of Partial Discharge on MV Switchgear. ProCorona can detect the presence of partial Discharge inside metal enclosed switchgear by listening to the sound inside the cubicle using a external sensor.
Perhaps you can check with Field Services Team if they still have this offer.
Hope helps
faisalamir
Lieutenant
Hi Pak Helvin,
Faisal
