Ecostruxure power commission
  • Power Distribution IEC
  • Ecostruxure power commission
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
MasterPact MTZ
EcoStruxure™ Power Commission
Jos_GRT
Lieutenant | EcoXpert Master Jos_GRT Lieutenant | EcoXpert Master
Posted: ‎2022-12-01 10:59 PM
3
1912
In the previous version of EPC, you could find an nice overview of the installed Digital modules the MTZ breaker, by logging inn on the breaker and goin to the page "Digital Modules".  The installed Modules were clearly visible and marked on top of the page. Since the last update of EPC, the overview of the installed digital modules doesn't show anymore what modules are installed,
Is that an EPC Bug or has this been changed for some reason? Is there another way I can list an overview of the installed DM's in an MTZ breaker.
Jos_GRT
Posted: ‎2022-12-08 01:43 AM
In response to UdhayakumarAK
1857
Hello@udhayakumar,
EPC version: 2.26.1
Breaker type is: Masterpact MTZ-Micrologic 5.0 X (Updated with the last Fw version at present: 005.103.003)
Jos
UdhayakumarAK
Commander UdhayakumarAK Commander
Commander
Posted: ‎2022-12-06 01:54 AM
1882
Hello @Jos_GRT
Just to confirm, are you mentioning the latest release 2.26.1?
Please specify the EPC version and type of breaker/ION module details.
Thanks!
Regards
Udhay
Regards
Udhayakumar A K
ESXP System Support Expert
Jos_GRT
1858
Hello@udhayakumar,
EPC version: 2.26.1
Jos
Jos_GRT
Posted: ‎2022-12-14 05:12 AM
In response to Jos_GRT
This answer above, was just a confirmation to the question to confirm what version of EPC and which kind of breaker I had an issue.  It is not the solution!
The issue is still that, since the last upgrade of EPC, I can no longer see the installed digital modules in the overview screen, when I log on to the breaker. I have this issue now with all the MTZ breakers that i am commissioning.
Rgegards,
Jos
