Railway 16 2/3 Hz 230 V MCB
  • Power Distribution IEC
  • Railway 16 2/3 Hz 230 V MCB
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Fredrik_Aandal
Ensign Fredrik_Aandal Ensign
Ensign
Posted: ‎2022-12-14 02:56 AM
9
2436
Hi community
I'm not able to find any MCB's with specifications for 16 2/3 Hz. I would assume a magnetic trip correction factor must be applied, but only DC factors are currently specified.
Anyone who has found any solution to similar topic?
  • Products
Yarom
Lieutenant Yarom Lieutenant
Lieutenant
Posted: ‎2022-12-14 03:46 AM
6
2432
To start and get you going before someone else comes with a more relevant answer, we have MCCB's (NSX series) that may offer a solution.
Check out page B-54 (88 of the pdf):
https://download.schneider-electric.com/files?p_enDocType=Catalog&p_File_Name=LVPED221001EN.pdf&p_Do...
Hope it helps.
Replies 9
Yarom
Lieutenant
6
2433
Hope it helps.
Gregoire_Brun
Commander
Posted: ‎2022-12-14 05:16 AM
2419
Hello
Right @Yarom
@Fredrik_Aandal, I'm surprise to see a question coming from Norway for this type of device which is generally dedicated for Switzerland and Austria railway... what is your application on your case?
Gregoire Brun
Breaker Product Expert
Fredrik_Aandal
Ensign
Posted: ‎2022-12-14 11:33 AM
In response to Yarom
2416
Thanks, I'm aware of NSX 16 2/3 Hz compatibility. Using a MCCB as a substitute for MCB is a bit overkill though.
Fredrik_Aandal
Ensign
Posted: ‎2022-12-14 11:35 AM
In response to Gregoire_Brun
Norway has 16 2/3 Hz railway just as Switzerland and Austria. And don't forget about Germany.
Gregoire_Brun
Commander
Posted: ‎2022-12-15 02:25 AM . Last Modified: ‎2022-12-15 02:25 AM
In response to Fredrik_Aandal
2403
@Fredrik_Aandal what is the ratting and short circuit level you need ?
Gregoire Brun
Fredrik_Aandal
Ensign
Posted: ‎2022-12-15 06:15 AM
2396
@Gregoire_Brun 2-pole in the range of In 6 - 10 A B/C trip. char.
Isc levels are quite low as the 15 kV - 230 V transformer is at maximum 15 kVA. "Standard" Icu/Icn will do the job.
Gregoire_Brun
Commander
Posted: ‎2022-12-15 06:42 AM
2392
Same ratio of 10 % lower could be apply for MCB I think
Gregoire Brun
Fredrik_Aandal
Ensign
Posted: ‎2022-12-15 07:18 AM
2391
Thanks Gregoire,
I agree with you that the same factors probably would apply MCBs as well. But before stating this to a customer I will need to get it confirmed by technical support in an email.
Gregoire_Brun
Commander
Posted: ‎2022-12-15 08:00 AM
if you want an official declaration, please contact CCC to optain it,Aks them eventualy to contact me to cross data between MCCB and MCB
Gregoire Brun
