1600A Bolted-Pressure switch
  • Power Distribution IEC
  • 1600A Bolted-Pressure switch
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2022-12-08 08:09 AM
1
1375
Looking for some help on how to configure a switchboard in product selector with a 1600A Bolted-Pressure switch.
Issue:
Selecting a part number for a 1600A or above, disconnect switch in a NEMA 3R enclosure
Product Line:
Switchboard
Environment:
QED 2, BP switch
Resolution:
Product will need to be configured as a N3R switchboard with a Bolted-Pressure switch.
This can be done using QuoteFast, EQM, or product selectors. Contact your local distributor for a quotation.
Be sure to confirm the system voltage because a ground fault relay is needed for a 480/277v switch for service entrance.
Gregoire_Brun
Commander
Posted: ‎2022-12-13 05:15 AM
hello @Anonymous user , is it a question link with safety switch range ?
@Christo.Thomas , maybe you can help for it ?
Gregoire Brun
Breaker Product Expert
Gregoire_Brun
Commander
Gregoire Brun
