EVLink Load Management System - Direct Serial Connection Communication Settings
  • Power Distribution IEC
  • EVLink Load Management System - Direct Serial Connection Communication Settings
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EVlink Load Management System
swil
Commander swil
Commander
Posted: ‎2021-01-31 08:59 PM . Last Modified: ‎2022-02-02 01:51 AM
5
5287
I can't seem to find an EVLInk forum. Is there one?
The HMIBSCEA53D1EDS LMS system installation guide and user guide do not seem to indicate what serial settings are appropriate for direct serial connection to a meter, or wiring connections.
I'm trying to connect an iEM3455 LVCT meter to the LMS.
Any assistance would be appreciated.
  • Connectivity
  • eMobility
  • Sustainability
adrien-g
Ensign adrien-g Ensign
Ensign
Posted: ‎2021-02-01 09:10 AM
2
5244
Dear @swil ,
Thank you for your question. You will find below some details on the way to connect a Power Meter to EVlink LMS using a Modbus Serial connection.
The picture below gives you information about plug and connectors to make the physical connection within your installation.
You will find attach a datasheet of a sample 'USB to RS485' Serial Converter cable that we used to do such installation.
The picture below explains how to configure the Powermeter during the configuration. The RTU option has to be checked
I hope that these information will help you. Feel free to come back to us if you have additional question.
adrien-g
Ensign
Posted: ‎2021-02-02 01:10 AM
In response to swil
Dear swil,
Baud rate is '19200' and parity is 'none' which i guess are the default settings. COM.Protection has to be set to disable as well.
The serial connector should work as well for Direct Serial Connection with the Power Meter.
Adrien
Replies 5
J_Travostino
Sisko
Posted: ‎2021-02-01 05:09 AM
Hello @swil
Thanks for reaching us.
As we currently do not have a dedicated forum on EVLink, you are at the right place.
We'll be back to you pretty soon.
BR
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
adrien-g
Ensign
2
5245
Dear @swil ,
swil
Commander swil
Commander
Posted: ‎2021-02-01 02:29 PM
In response to adrien-g
1
5237
Thank you, @adrien-g. I will try to locate that USB hardware.  The only hint as to how to connect LMS directly to serial meters in the user manual/installation is shown in the attached image.
I have two additional questions:
1. Have you used this method to connect a iEM3x5x meter directly over serial to an LMS unit?
2. Were the baud rate / parity settings used the factory default settings for the iEM3x5x meter?
adrien-g
Ensign
In response to swil
Dear swil,
Adrien
SebTTG
Lieutenant SebTTG Lieutenant
Lieutenant
Posted: ‎2021-02-24 01:27 AM
Great sharing ! Thanks
STT - EcoXpert LV & MV badge owner
