Cable Thermal Stress Curves
  • Power Distribution IEC
  • Cable Thermal Stress Curves
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Design – Ecodial
Stephen_Breayley
Stephen_Breayley
Cadet
Posted: ‎2023-12-06 11:13 AM . Last Modified: ‎2024-11-22 04:25 AM
1445
How do you show the cable curves on the protection curve tab?
  • Power Distribution Software
Genghiz
Captain
Posted: ‎2023-12-07 03:44 AM
Thanks for reaching the “EcoStruxure Power Design Forum.”
In Ecodial application, the cable curve can be seen along with the protection on the ‘Curves’ tab.
Steps:
  1. Ensure the network calculation is completed.
  2. Select the circuit at which the ‘cable curve’ needs to be analyzed.
  3. Click on the ‘Protection’ (circuit breaker), the same is highlighted in green now.
  4. Click on the ‘Curves’ tab.
  5. Select from the drop down, the choice as ‘Cable.’
Cable CurveCable Curve
Conclusion:
Through the above steps, you will be able to see the ‘required cable curves’ along with the protection available for that circuit.
Thanks & Regards,
Team - Ecodial Expert Support.
Genghiz
Captain
Steps:
Conclusion:
Thanks & Regards,
