Posted: 2024-01-31 09:38 AM
I'm trying to write my HMI server time to the RRTC on a M580. I have been referencing the technote:
"In the M580 CPU, why does the system word %SW51 (RTC Hour) show a different value?"
I'm reading from the RRTC just fine using this note. I can also write to the system variables (%SWXX), but not the hour. Is there an elegant way to write to the RRTC that doesn't use the defunct system word %SW51 (RTC Hour)?
Posted: 2024-02-01 08:51 PM
I am not sure why you are having the issue. Please note that the RTC is organized as per the attached document. %SW51 is expressed in hex and contains 16#HHMM where HH is the hexadecimal equivalent of hours 0-23 and MM is 0-59 minutes.
see the system word manual.. https://www.se.com/au/en/download/document/EIO0000002135
Posted: 2024-02-04 04:45 PM
The M580 uses UTC in one and local time in the other. I can't remember which way around. That will account for your different values. We had to modify our PLC clock RTC sync DFB to accommodate this difference from the M340.
Posted: 2024-02-05 05:40 AM
RRTC block has only outputs so you will not be able to write to it.
I believe you should be able to use local time with WRTC_DT block.
Posted: 2024-05-02 01:44 AM
