The READ_VAR between two Simulator Control Expert V14.1
Modicon PAC Forum
  • Industrial Automation
  • Modicon PAC Forum
  • The READ_VAR between two Simulator Control Expert V14.1
Trinxs1
Commander Trinxs1 Commander
11
YONGHO-KIM
Lieutenant YONGHO-KIM Lieutenant
9
ciupol
Lt. Commander ciupol
9
Back to Modicon PAC Forum
ahcoelho
Crewman ahcoelho
Crewman
Posted: ‎2024-04-26 09:23 PM
1411
I’m attempt to establish a communication between two simulator M580 CPUs, using a READ_VAR, I have two vitalization Windows 10 in VMWare and each one with Control Expert V14.1 Installed, that I can ping each other, I create a new program with CPU M580, crate a section with READ_VAR, put the configuration of block, especially the address using the block ADDMX, I’ve trayed a lot of strings in input ADDMX, however the in/out GEST in READ_VAR block return value #16003 (Incorrect address format) doesn’t matter what I into in ADDMS’s input. I’m think that Control Expert 14.1 don’t work with communication between two Simulators, but I couldn’t find this information anywhere. Someone already has this issue? Someone two help me?
  • 02. Modicon M580 ePAC
  • 05. Networking & Communication
  • 06. EcoStruxure Control Expert
  • controlExpert
  • m580
  • simulator
PatrickVanDijk
Lieutenant JG PatrickVanDijk
Lieutenant JG
Posted: ‎2024-04-30 11:21 PM
I'm not sure about the errors, but direct communication between simulators is not possible. This is probably to prevent using simulators as production controllers.
ahcoelho
Crewman ahcoelho
Crewman
Posted: ‎2024-05-02 06:32 PM
Thanks, I have found the answer, the communication between PLCs Simulators on Control Expert just work in Libset 15.0 or later, this information is just on help of V15.0 and later.
