Continue
  • My Subscriptions
  • Events
Writing to RRTC on a M580
Modicon PAC Forum
  • Industrial Automation
  • Modicon PAC Forum
  • Writing to RRTC on a M580
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Super_88
Super_88
Explorer
Posted: ‎2024-01-31 09:38 AM
2981
I'm trying to write my HMI server time to the RRTC on a M580. I have been referencing the technote:
"In the M580 CPU, why does the system word %SW51 (RTC Hour) show a different value?"
I'm reading from the RRTC just fine using this note. I can also write to the system variables (%SWXX), but not the hour. Is there an elegant way to write to the RRTC that doesn't use the defunct  system word %SW51 (RTC Hour)?
  • 02. Modicon M580 ePAC
Replies 4
Trinxs1
Trinxs1 Leader
Leader
Posted: ‎2024-02-01 08:51 PM
I am not sure why you are having the issue.  Please note that the RTC is organized as per the attached document.  %SW51 is expressed in hex and contains 16#HHMM where HH is the hexadecimal equivalent of hours 0-23 and MM is 0-59 minutes.
see the system word manual..  https://www.se.com/au/en/download/document/EIO0000002135
Trinxs
MatthewM
MatthewM
Mentor
Posted: ‎2024-02-04 04:45 PM
The M580 uses UTC in one and local time in the other.  I can't remember which way around.  That will account for your different values.  We had to modify our PLC clock RTC sync DFB to accommodate this difference from the M340.
ciupol
ciupol
Mentor
Posted: ‎2024-02-05 05:40 AM
RRTC block has only outputs so you will not be able to write to it.
I believe you should be able to use local time with WRTC_DT block.
JeriLester578
JeriLester578
Explorer
Posted: ‎2024-05-02 01:44 AM
