Posted: 2025-02-14 07:11 PM
Posted: 2025-02-18 02:57 AM . Last Modified: 2025-02-18 10:08 PM
Show us your code and maybe someone can help you figure it out. But the first thing that comes to my mind is if you set a timeout in the GEST variable? The third INT in a 1..4 array should be set to 10 for example for 1000ms timeout. And don't forget to save this array in a %MW so it retains its value or make sure this third INT is set at at least each PLC start.
Posted: 2025-02-24 09:21 AM
Is the GEST animation from when it has stopped working? A 7 in the second int's least significant byte means "Problem in sending to the destination". I have no idea what could cause that 😞
7424 (bit 0 is not set) also tells us it is not waiting for something which is also a bit strange but that might be that your "round robin" trigger tells it to hold in this exact moment.
Is that first int counting/changing or is it frozen? How is bit 0 in it behaving?
I think I would capture the communication at network level with wireshark to better understand what really happens. I would also try what happens if you change the communication to another device like another PLC to see if it has something to do with this particular device.
Posted: 2025-02-24 10:24 AM
Another thing that comes to my mind, what version is the CPU firmware?
Posted: 2025-02-24 07:52 PM
Firmware version of CPU - 3.22
Posted: 2025-02-24 08:56 PM
Hi, It could be that the relay stops responding. Have you tried poling the same register using a modbus simulator (plenty free ones on the web)?
With Modbus comms I always start by using a Modbus Simulator from my PC to the device as this eliminates a lot of uncertainties.
Posted: 2025-02-24 10:22 PM
3.22 skuld be good, last in 3.x line. 4.x is mostly about security/new features so it would probably not help. My bet is that this has something to do with the specific device.
Posted: 2025-02-25 12:15 AM
Yes i have tried from Modscan. But the problem is after timeout when i download the program again, it works till timeout. So i dont think the relay stops responding.
Posted: 2025-02-25 12:18 AM
Which security features need to enable for this?
Posted: 2025-02-25 09:33 AM
Now I don't understand what you mean?
Posted: 2025-02-25 07:49 PM
Is there any features to enable for timeout or anything to check in specific device?
Posted: 2025-02-26 07:52 AM . Last Modified: 2025-02-26 08:25 AM
I would try to change address on the read_var block from 3 to 2 or 4 to eliminate register vs offset address issue.
