M580 Safety use of Analog Inputs (BMXSAI0410)
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • M580 Safety use of Analog Inputs (BMXSAI0410)
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
MatthewM
MatthewM
Mentor
Posted: ‎2024-06-11 02:34 PM
3103
Hi everyone,
Has anyone out there used analogue inputs in safety applications?  We have a BMXSAI0410.  There are no functions available in safety code for scaling from raw to EU.  Do we just get used to the idea of working in raw only, or do we scale it manually with half a dozen math blocks?
  • 03. Modicon PAC Safety
Farzad_Samimi
Farzad_Samimi Contributor
Contributor
Posted: ‎2024-06-13 05:18 AM
3030
Hi Matthew,
There is a demo project for M580s when you install Control Expert, there is a DFB create for safety section that scales the analog input.
Replies 4
Hennie_Smith
Hennie_Smith Mentor
Mentor
Posted: ‎2024-06-11 09:37 PM
3068
Hi. The SAFE sections should be used only for the safety logic based on the Cause&Effect matrix compiled during the Risk assessment. (Comparisons will need to be with the RAW values). To scale the values for HMI/SCADA purposes you can read the values via the interface in the PROCESS sections and scale it accordingly.
MatthewM
MatthewM
Mentor
Posted: ‎2024-06-12 08:45 PM
In response to Hennie_Smith
Thanks for the reply.  Yes I am already scaling in the Process section for SCADA, but I do find it odd that it is expected to use RAW in the safety application.  I thought the days of having to use RAW died with 984.  Apparently not.
Cheers.
Farzad_Samimi
Contributor
3031
Hi Matthew,
MatthewM
MatthewM
Mentor
Posted: ‎2024-06-16 04:12 PM . Last Modified: ‎2024-06-16 04:14 PM
In response to Farzad_Samimi
Thanks for that.  I had not found that demo app.  I will mark this as a solution, even though I requires making a DFB (using system Safety Functions).  The client site does not want is to create DFBs for safety, so I will either have to replicate the contents of the DFB for each analog (only 2), or just live with using RAW.
