Posted: 2021-04-04 12:12 AM
Dear Viewer,
I am trying to download a program in M221 PLC and its getting failed.
Error messages are attached herewith.
Kindly provide a solution and make me move forward.
Software version - somachine basic v1.3
BR
Kishore.
Posted: 2021-04-07 10:50 PM
Did you use an TM3 expansion on the TM221? If yes did you check if the modul is phsyical identical with your configuration? Do you try to download an older project file? Was your test via USB or via Ethernet?
Posted: 2021-04-08 12:06 AM
Pls check with the following answers.
Did you use an TM3 expansion on the TM221? NO
Do you try to download an older project file? NO, It is suppose to be my 1st download. but couldnt able to do that.
Was your test via USB or via Ethernet? Its USB
After long attempts, I finally moved to Ecostructure machine expert basic and its going well now.
Thanks for your valuable time.
Posted: 2021-04-08 12:08 AM
OK thank you for the feedback. Then the FW on the PLC seems to be the problem. Somachine Basic was replaced by ESME Basic a few years ago. Have fun with ESME Basic an TM221
