Posted: 2024-01-02 09:53 PM
Anyone have experience setup Ethernet I/P communication between M580 and FactoryTalk View via RSLinx? Any sample configuration available?
Posted: 2024-01-18 05:24 AM
I have attached document from Schneider how to establish EIP communication. Also attached is eds file. Hope this helps.
Posted: 2024-01-02 11:00 PM
Hello Keithcchan
I took serval print screens that illustrate the required steps to add Ethernet I/P device and new EDS files and establish communication link.
but anyway I think the configuration could be implemented easily from the "FactoryTalk View" side if it supports the M580.
Posted: 2024-01-03 10:14 PM
Yes you probably could but why would want to? Factory Talk View has a Modbus TCP driver so you can talk directly to M580 and avoid all the RSLynx garbage. That frequently breaks then your process is up a creek.
The drive uses either modbus or Control Expert addressing. So it would be much faster that an Ethernet IP scheme with Linx.
Posted: 2024-01-14 11:26 AM
If you want to read unlocated tags, you would need to use OFS to provide PLC data via OPC. From that point I think it should possible to add it as an OPC data source into FTView.
Posted: 2025-05-13 06:59 PM
Can you elaborate on the FTV Modbus TCP driver?
I've always had to use an OPC like Kepware or OFS to talk/read Modbus TCP with FTV.
Posted: 2025-05-13 10:45 PM
Can you explain how to do communication settings in Factory talk ME HMI Software ?
