TM171 RS485 Malfunction
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • TM171 RS485 Malfunction
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Josh1
Josh1
Explorer
Posted: ‎2023-10-05 11:24 AM
1154
Im using Modicon TM171O
Whenever I upload program to the PLC, After the power cycle it does not reconnect to the Ecostuxure HVAC software.
It shows the error "Can not connect to the target"
Im certain of the modbus parameters, im using plc address as 1, baudrate as 9600, parity as Even.
Can someone help? Thanks!
  • 00. Read me first
KosmoDrome
KosmoDrome
Explorer
Posted: ‎2025-05-01 04:46 AM
Hi, I have the same problem.  Have project with Fancoil Units - 4 pcs. at one place. Each of them have own TM171ODM22R and connects to BMS by modbus. Suddenly 3 of 4 units lost the 485 connection and impossible to connect throug the program cable and Ecostructure HVAC anymore.  CAN NOT CONNECT TO THE TARGET.
Installed new ones TM171, ECOSTRUCTURE HVAC programm uploaded ok to the unit, after power cycle all was still good. But after I connected it to the system with other units, again lost connection and cant do it anymore. CAN ANYBODY HELP?
Bastian_Schmitz
Bastian_Schmitz Champion
Champion
Posted: ‎2025-05-09 06:24 AM
TM171O has only 1 Serial Line. Internal the RS485 ressources are shared with the DMI ressources. A combind connection is not possible. If you need a combinde connection you need to add a TM171ALAN Modul. In that case you get a second serial line. Or you use TM173O instead. The new one has not longer such a problem.
