Control Expert V15 on Windows 11 VM
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • Control Expert V15 on Windows 11 VM
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Jalber
Jalber
Contributor
Posted: ‎2024-11-20 01:02 PM
4491
I am trying to run control expert and am having performance issues while online with the PLC.  I am running VMWare workstation V17.5 with Windows11.  While using control expert offline, not connected to the PLC, the performance is acceptable; a little slow to startup but manageable.
When connected to the PLC with either ethernet or the USB cable it becomes very, very slow.   If I switch between between routines, it takes anywhere from a few seconds to upwards of 15 seconds to fully load the routine and get the updated status of the variables.  If I try and make online edits, it takes even longer to load.  The build and download of the updates is fine speed wise, it just seems to be the loading of the routine pages (I use FBD) as I switch from one to another or when starting and doing edits.
Has anyone encountered this before?  I have reloaded the software, tried a new VM amongst other things.
John
  • 06. EcoStruxure Control Expert
maidamar
maidamar
Contributor
Posted: ‎2025-01-09 04:23 AM
1
4445
Also, I've had some luck in the past disabling "Accelerate 3D graphics".
triden55
triden55
Contributor
Posted: ‎2025-01-13 03:03 PM
4378
It's a VMware issue.  Right-click VMware -> Run as Administrator and I'll bet it will fix all your slowness.
Replies 7
Trinxs1
Trinxs1 Leader
Leader
Posted: ‎2025-01-08 10:24 PM
1
4489
this is not necessarily a solution.  Please note that V15.0, V15.0 SP1, V15.1 and V15.2 have been validated for WINDOWS 10 64 bit.
V15.3 and onwards has been validated for WINDOWS 11 as per the table from the readme.Pdf.
VMWare V15.5 was recommended for V15.3 of ECE.
Later versions such V16.1 to run better and support later operating systems.  i.e.
This does not solve your problem unless you update to V15.3
Trinxs
Senior Technical Sales Consultant - PAC
PatrickVanDijk
PatrickVanDijk
Troubleshooter
Posted: ‎2025-01-09 01:14 AM
I always try to find out whether there is a resource bottleneck by running Windows Task Manager (in the VM and also on the host machine).
Please look at the CPU, RAM, and disk performance values.
For instance, if the amount of RAM is insufficient, Windows will swap some memory blocks to the hard disk, making your applications way slower. Add more RAM to the VM in this case (if available on the host).
CPU performance is not so easily addressed. If your host machine is not bottlenecked, you can try to add a extra vCPU (core) to the VM, but I'm not sure how well Control Expert will handle multi-CPU / multithreading.
For harddisk performance, I can only recommend using SSD drives and not running your VM from a mechanical hard drive, nor from a removable (USB) medium.
maidamar
maidamar
Contributor
1
4446
triden55
triden55
Contributor
4379
Jalber
Jalber
Contributor
Posted: ‎2025-01-15 05:16 AM
In response to maidamar
Thank you.  I have done this and see some improvement.
Jalber
Jalber
Contributor
Posted: ‎2025-01-15 05:22 AM
In response to Trinxs1
Thank you for the reply.  Unfortunately, I am locked into using V15 SP1 due to clients preference.  I will look into setting up a Windows 10 64 bit VM.
Jalber
Jalber
Contributor
Posted: ‎2025-01-17 05:24 AM
In response to triden55
This made a huge difference, although I'm not sure why.
