Device discovery in IT Expert
  • EcoStruxure IT Help Center
  • IT Expert
  • Configuration
  • Device discovery in IT Expert
  • My Knowledge Base Contributions
  • Invite a Friend
The article you are trying to access is permanently deleted.
  • Administration
  • Alarms
  • Dashboard
  • Device configuration
  • Firmware update
  • ITE Configuration
  • Modeling in IT Expert
  • Single Sign On (SSO)
Thumbnail of EcoStruxure™ IT Expert
1
EcoStruxure IT Support
Request Support
Sort by:
Default
  • Default
  • Date
  • Views
  • Likes
  • Comments
  • Invite a Friend
Video: Device discovery in IT Expert
      Administrators and Operator users with permissions for All locations can discover devices on up to three EcoStruxure IT Gateways at a time in IT Expert. An IT Expert subscription is not required.   Modbus device discovery in IT Expert is not supported. You discover Modbus devices in the Gateway software interface.   Requirements   Available only for Administrators and Operator users with permissions for All locations Gateway software version must be 1.23.1 or newer. Gateways must be registered in IT Expert. Active Device Communication credentials and File Transfer credentials must be configured on each Gateway first.   If some of your Gateways do not meet the requirements for device discovery: Log in to each Gateway and check that credentials are configured and that the Gateway software is up to date. Go to Administration > Gateways to see information for the Gateways in your organization.       Go to Device discovery.    1. Enter the IP addresses or address range of the SNMPv1, SNMPv3, NetBotz, and Redfish devices to discover, or import a device list.    2. Click the arrow to display all available Gateways in your organization. Select up to three Gateways to discover devices on.    Gateways that do not meet requirements for device discovery are not listed.  Offline Gateway are listed. Make sure to choose Gateways that are online. Go to Administration > Gateways to see the status of the Gateways in your organization.     3. Select the location where you want to discover the devices. Devices can be moved into other locations after discovery if needed.   4. Click Configure credentials.   All credentials is selected by default for both Discovery and Polling credential types and Device File Transfer credentials. Click the arrow to see the list of available credentials.     At least one Discovery and Polling and one Device File Transfer credential per Gateway is required.   IMPORTANT: If you create or modify credentials on any Gateway while logged in to ITE, refresh the ITE page before you proceed with discovery.     5. Click Discover devices.   All discovered devices are listed on the Devices page in All locations and in the location you selected. You can move devices into other locations after discovery if needed.     Search for your newly discovered devices in All locations by their IP address range.   Discovered devices are visible in IT Expert and on all the selected Gateways. All the Gateways that have discovered the device are listed in Properties on the device details page.     Discovery results are displayed in the summary including discovered devices, devices that require attention, and unsupported devices that were not discovered. Click View details. Click View log to see details and see discovery results in the discovery log.   SNMP devices that cannot be automatically identified after discovery are listed in the discovery results as Unable to identify devices. To complete the discovery, log in to the Gateway(s) and select the DDF to use for this device.   If you find that one or more of your devices is not supported, you can request device support.     Note: Your APC NMC3 devices might be configured to limit the number of failed login attempts. If the number of device file transfer credentials you provide in the Gateway exceeds the number of failed login attempts allowed on the NMC3 device, the device might be locked.
View full article
Sisko JLehr Sisko
‎2025-02-10 01:08 PM
Import a device list to discover devices in IT Expert
Administrators and Operator users with permissions for All locations can import a device list from Data Center Expert or another source to easily discover devices in IT Expert on up to three EcoStruxure IT Gateways. An IT Expert subscription is not required.   Modbus device discovery is not supported in EcoStruxure IT.   See Device discovery in IT Expert   File format IP addresses to discover must be in a single column. The columns do not need to be in any specific order. Any extra columns are ignored. The first row can optionally be a header row describing the contents of each column. A header row is not required. The file extension must be .csv, .tsv, .txt The column delimiter must one of the following: colon, comma, tab, pipe, semi-colon, space. The character encoding on the file must be UTF-8. Example IP address 192.168.1.12 192.168.1.25 192.168.1.32 192.168.1.42
View full article
Sisko JLehr Sisko
on ‎2025-02-10 01:08 PM
Move devices between locations in IT Expert
  You use the location hierarchy on the Devices, Alarms, or Floor layout pages between locations in your organization.   Click the list icon to view the expanded hierarchy if needed.      Click the toggle to show the list of devices for the selected location. Unassigned devices are listed when All locations is selected.   Select the devices you want to move. Click Move x devices. Choose the destination location in the hierarchy. Click Move.
View full article
Sisko JLehr Sisko
‎2025-09-12 06:55 AM
on ‎2025-09-12 06:55 AM
Discover PDU in DCE or ITE after replacing the display module with APDU9640NMC3
  After you replace the display module in a 10000 series PDU with the new APDU9640NMC3, it is recommended that you delete the PDU devices previously discovered in Data Center Expert or IT Expert and rediscover them. This will cause historical data loss.   Options to retain historical sensor data include:   Download the data and save it before you delete the originally discovered PDUs and rediscover the updated PDUs.   In DCE or ITE, put the originally discovered PDUs in maintenance mode, and then rediscover the updated PDUs under a new IP address. Note: This option uses twice the number of nodes.   In DCE or ITE, rediscover the updated PDUs using the same IP address. Delete the sensors that are not important to you. The status of the remaining sensors from the previously discovered PDUs will be Unplugged.   Backup your DCE server. Delete the originally discovered PDUs and add the updated PDUs as new devices. If the historical data is needed, the backup can be restored and the data can be accessed.   IMPORTANT: After the display module is replaced in the 10K PDU, it still reports its model as a 10000 series device, APDU10Kxxxxx.   You can tell which 10K PDUs have replacement NMC3 displays by the firmware application version. 10K PDUs with original display modules have firmware version 2.x.x.x. 10K PDUs with NMC3 display modules have firmware version v3.x.x.x.   Note: The 11K PDU model number is APDU11Kxxxxx with firmware version v3.x.x.x.
View full article
Sisko JLehr Sisko
‎2025-05-02 06:34 AM
  • 10K PDU
  • 11K PDU
Discover cascaded PDUs in EcoStruxure IT
  You can discover cascaded APC PDUs with a single PDU acting as the host for all the cascaded guest PDUs. Note: PDUs configured with RNA (Redundant Network Access) are not supported in EcoStruxure IT.   Check this article to see if your APC PDUs support cascading and learn how to configure them: https://www.apc.com/us/en/faqs/FA164436/   Once the host PDUs and all guest PDUs are configured for cascading, you can discover the host PDU in the EcoStruxure IT Gateway or in IT Expert. Device discovery in EcoStruxure IT Gateway Device discovery in IT Expert   When you discover the host PDU, all the connected guest PDUs are also discovered.  Each guest PDU will have the IP address of the host PDU and will display as separate devices in the Gateway and in IT Expert. Communication status between the Gateway and the cascaded PDUs is reported by the first PDU device in the cascade only.   Note: If the PDUs were previously discovered before they were configured for cascading, you must delete them, configure the hosts and all guest PDUs for cascading, and then rediscover the host PDUs.
View full article
Ensign AGray Ensign
‎2025-04-03 09:15 AM
Last Updated: Sisko JLehr Sisko ‎2025-07-02 09:04 AM
  • cascade
  • daisy chained
  • Gateway
  • Network Port Sharing
  • NPS
  • PDU
Didn't find what you are looking for? Ask our Experts
