Continue
  • My Subscriptions
  • Events
how to kwh parameter value reset using modbus tcp protocol / PM8240
Metering & Power Quality
  • EcoStruxure Power & Grid
  • how to kwh parameter value reset using modbus tcp protocol / PM8240
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2016-04-27 05:48 AM
1665
Device name
->PM8240
Communication Method
->Modbus TCP only
At the user site SI team question me, how to reset kwh value using only Modbus tcp protocol
Before I was check Modbus map it but kWh parameter can't reset.
Otherwise I can do it, PME handle easily but there user can’t it
Please give me good idea?
Yut
Yut
Leader
Posted: ‎2016-05-03 01:47 AM
1609
In general for ION meter the master reset is external pulse number 19(ep19) Modbus address is 42019 try it.
sesa56314
sesa56314 Leader
Leader
Posted: ‎2016-05-09 01:53 PM
External Pulse Module #19 is the Master Reset in the default framework.  It's output can be toggled via Modbus at address 52019 (write a 1 to address 52019).  Modbus Map Access in the Security Options Module must be set to Yes to enable this functionality.
