Continue
  • My Subscriptions
  • Events
Which power meters comply with a 4-wire + ground requirement?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Which power meters comply with a 4-wire + ground requirement?
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
sesa360183_brid
sesa360183_brid Leader
Leader
Posted: ‎2016-02-22 07:51 PM
2472
Will appreciate your help on this. Thank you!
Tags (3)
  • 4-wire
  • 4-wire plus ground
  • power meters
VictorMarincus
VictorMarincus Champion
Champion
Posted: ‎2016-03-14 12:40 AM
3
2395
The meters which can be connected in a "5 wire system" (3 phase conductors, a neutral conductor and a separate ground conductor - the building ground) are the ones which have the GND terminal on their chassis (advanced metering and utility metering)- ION8xxx and ION7xxx.
Replies 6
VictorMarincus
Champion
Posted: ‎2016-02-25 08:19 AM
2395
Is your question about the electrical network connection or about the meter communication port (old 4-wire RS485)?
sesa360183_brid
Leader
Posted: ‎2016-03-14 12:21 AM
2395
This is about the electrical network connection.
VictorMarincus
Champion
3
2395
sesa360183_brid
Leader
Posted: ‎2016-03-14 12:52 AM
This answers it. Thank you very much!
JamesAZZO
JamesAZZO
Leader
Posted: ‎2016-03-15 05:03 AM
2395
What about the PM8000?
VictorMarincus
Champion
Posted: ‎2016-03-15 06:11 AM
Hi James,
The PM meters, in general, do not have exposed metallic parts therefore they do not require a grounding to protective earth (PE).
