Continue
  • My Subscriptions
  • Events
【PowerLogic™ Current Transformers】Regarding the shape of the CT secondary side.
Metering & Power Quality
  • EcoStruxure Power & Grid
  • 【PowerLogic™ Current Transformers】Regarding the shape of the CT secondary side.
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Miyai
Miyai
Contributor
Posted: ‎2025-11-27 11:08 PM
1072
I'm not sure if this is the right place to post this in the community, do you know the shape of the secondary terminal of the CT?
I was asked the following two questions by a customer, but I can't find any information on Schneider's website.
aa) I would like to know the screw shape of the secondary terminal of the “METSECT5CC”. Customer needs information on how to connect wiring. If possible, I'd like to know the URL of the document.
bb) I would like to know the shape of the secondary terminal of the "METSECT5MA". If it is screw-fastened, I would like to know the screw diameter.
Best regards,
Miyai
  • Did you know
rohith-s
rohith-s Troubleshooter
Troubleshooter
Posted: ‎2026-01-04 10:17 PM
838
Hello @Jesus_Diaz  & @Miyai ,
aa) The secondary terminal screw used in the METSECT5CC model is M4 screw. We will update this information in the documentation.
bb) For the METSECT5MA model, pin-type lugs can be used to connect to the terminal.
Rohith S
Replies 5
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2025-11-28 11:02 AM
1055
Hi @Miyai,
The secondary connections are made using lug terminals, tunnel terminals, or screws.
The METSECT5CC uses screws, as you can see from the 3D model on se.com.
The METSECT5MA connections are shown below:
The most common practice is to use 22–18 AWG twisted-pair wire, and you can select the corresponding wire terminal.
JD
Miyai
Miyai
Contributor
Posted: ‎2025-11-30 04:38 PM
Hello  @Jesus_Diaz ,
aa)  “METSECT5CC”.
Do you know what size hole the terminal should be? Generally, the information on the compatible terminal shape should be listed in the specifications, but I can't find any information.
bb) "METSECT5MA"
Does this fit a pin terminal?
Best regards,
Miyai
Jesus_Diaz
Jesus_Diaz Leader
Leader
Posted: ‎2025-12-01 04:46 PM
Hi @rohith-s,
Could you please check @Miyai questions?
Thanks.
rohith-s
Troubleshooter
838
Rohith S
Miyai
Miyai
Contributor
Posted: ‎2026-01-04 10:45 PM
Hello @rohith-s
Thank you for your support.
Miyai
