Continue
  • My Subscriptions
  • Events
Position for calibration pulser modules not getting reset on ION meter
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Position for calibration pulser modules not getting reset on ION meter
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
217
Ramasamy_N
Ramasamy_N Champion
117
MatthewP
MatthewP Troubleshooter
Troubleshooter
Posted: ‎2015-06-03 04:44 PM
1117
While running some tests on a custom ION7550 framework I observed that the "position" of the calibrated pulser module is not getting reset despite having done a master reset on the device.
I would assume the master reset clears out everything (logs, energy, demand, min, max, ect.). But it appears the position on these modules is always remembered.
I am outputting a kWh pulse on R1 (1 kWh= 1pulse -> Kt=1000. I do a master reset, energy registers reset. However when  say 0.45kWh accumulates, the module pulses the port.
Is this normal intended behavior?
Yut
Yut
Leader
Posted: ‎2015-07-20 02:20 AM
Matthew,
Did you do resetting  when there was load ? If so one second after reset was done you will have energy accumulated for sure.
Yut
