PM5k Meter and BACnet
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5k Meter and BACnet
Charles_Murison
Picard Charles_Murison Picard
529
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
140
Ramasamy_N
Captain Ramasamy_N Captain
115
michael_franz
Admiral michael_franz
Admiral
Posted: ‎2016-08-10 08:52 AM
4
1999
Last night we upgraded a PM5560 to firmware 2.3.0.  Used FTP.  Found out user2 pass2 worked for FTP.  Power cycled the meter to initiate the upgrade.  Once done BACnet options appeared.  Very cool.  BACnet and Modbus at the same time over Ethernet.  Thanks Schneider-Electric.
Tags (3)
  • bacnet
  • modbus
  • pm5560
Replies 4
sesa52700
sesa52700 Schneider Alumni (Retired)
Posted: ‎2016-08-22 07:37 AM
1
1951
Hi Michael,
Would you mind summarizing the application to explain why you are using the two protocols at the same time. It might be interesting to use it as an example in our documentation.
Thanks!
michael_franz
Admiral
Posted: ‎2016-08-22 11:12 AM
Margaret:
We have many applications where we need both PME and a BAS system need simultaneous data from our meters.  Most of the time we need to use a ProtoNode, RTA or Babel Buster to get this to a BACnet system.  Having Both on the same device at the same time saves on parts, getting another IP address and just downright make the job a snap.
Contact me with any other questions about this kind of deployment.
Michael
Posted: ‎2017-02-14 07:16 PM
1
1951
Hello Michael Michael Franz,
Just to clarify, the power meter communicates BACnet and Modbus both at the same time via Ethernet? OR is it one at a time (reconfigurable which protocol would communicate via Ethernet) OR Modbus via the serial port and BACnet via Ethernet? Thanks.
michael_franz
Admiral
Posted: ‎2017-02-15 06:01 AM
Dion:
Both at the same time over Ethernet.  Beauty is PME and SBO at the same time.  Try it yourself to confirm.  There are real world applications for this.
Michael
