Continue
  • My Subscriptions
  • Events
PM5000 product simulator with QR codes available on Promote and Sell
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM5000 product simulator with QR codes available on Promote and Sell
Charles_Murison
Charles_Murison Champion
581
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Daniel_Brandao
Daniel_Brandao Mentor
Mentor
Posted: ‎2014-11-26 11:22 AM
11
3733
Hi guys,
I've just uploaded a product simulator for PM5000 meters on the "Promote and Sell" are of the community (Demos and Videos). This version has QR codes implemented, so it's the ideal way to get familiar with the feature and / or present it to customers without the need of having an actual meter with you.
The version is valid for 30 days.
Link: https://powersolutionscommunity.schneider-electric.com/community/power-monitoring-hardware/promote-a...
Enjoy!
Tags (3)
  • codes
  • pm5000
  • qr
Bojan
Bojan Leader
Leader
Posted: ‎2014-11-26 11:28 AM
3406
Hi Daniel,
I've just tried to run it on my Windows 7 laptop and it crashed:
Problem signature:
Problem Event Name: APPCRASH
Application Name: SimulationFull_B8_30DAY_TRIAL.exe
Application Version: 0.0.0.0
Application Timestamp: 543bfa28
Fault Module Name: SimulationFull_B8_30DAY_TRIAL.exe
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 543bfa28
Exception Code: 80000003
Exception Offset: 003121b9
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Replies 11
Bojan
Bojan Leader
Leader
3406
Hi Daniel,
Problem signature:
Locale ID: 1033
Daniel_Brandao
Mentor
Posted: ‎2014-11-26 12:22 PM
3406
Hi Bojar, this is the first time I hear about this error. I am talking with the developers to check if there's anything we can do. In the meantime, have you tried to install in a different computer? We do have the simulator installed on Windows 7 and it works.
Bojan
Bojan Leader
Leader
Posted: ‎2014-11-26 12:37 PM
Hi Daniel,
I tried to reproduce the crash, but it's Ok now - I have no idea what had happened first time.
Thank you,
Bojan
Posted: ‎2014-12-22 01:44 AM
3406
Hi Daniel,
When I click the above link it says unauthorized access?
sesa44646
sesa44646 Leader
Leader
Posted: ‎2014-12-22 08:58 AM
3406
Try again Poonam, I expect the issue was that you needed to be added to the Schneider group, which I have done.
Posted: ‎2014-12-23 12:48 AM
Thanks Vince
Posted: ‎2014-12-23 03:30 AM
3406
Hi Daniel,
It is very good tool. It is not only for QR code, but also for programming.
When I scan the QR code for log1, log2 etc., it shows 404 nothing found at this URL. I guess it might be because of lack of data?
Jixing
Daniel_Brandao
Mentor
Posted: ‎2014-12-23 09:34 AM
3406
Hi Jixing, not really. Even with no data you should be directed to meterinsights.com. I will check what's going on and let you know.
Posted: ‎2014-12-24 02:39 AM
3406
Hi Daniel, I just tried it again. It works, but only have one bar data.
Sam_Gaib
Sam_Gaib Troubleshooter
Troubleshooter
Posted: ‎2015-01-07 03:10 PM
Hi Jixing,
I am in charge of managing the Meter Insights + QR code project
I can confirm that if the meter (or simulator in this case) has less than 2 entries in the Log, Meter Insights will report a 404 error.  This is because Meter Insights displays the incremental accumulation in a logging interval (between two consecutive logs) so can't compute this unless it has at least two logs.  We deemed this to be a special/rare case that would only appear if the meter was powered up for the very first time and someone attempted to scan within the first 30mins (assuming 15min logging interval).  Nevertheless, the defect has been logged should we decide to implement a more user-friendly error-handling approach.
Furthermore, if the simulator only generates to Logs, this will be represented as one bar of data as you've observed
I hope this helps to clarify what you've experienced but please don't hesitate to share other questions or observations
Thank you
sam
Daniel_Brandao
Mentor
Posted: ‎2015-02-02 12:32 PM
New version with no expire available on Promote and Sell:
