Continue
  • My Subscriptions
  • Events
PM3255 Digital Output - External Mode
Metering & Power Quality
  • EcoStruxure Power & Grid
  • PM3255 Digital Output - External Mode
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2016-09-08 09:37 PM
2636
I'm struggling to work out how to enable the External mode for the digital output for the PM3255. Is this dependent on the firmware or possibly some other setting? I've been through the configuration on the meter itself and only get 3 options for both DO1 and DO2. Any ideas out there?
Anirban
Anirban Champion
Champion
Posted: ‎2016-09-14 09:21 PM
2541
Hi Paul,
You can change the DO mode to External from the meter front panel. Go to Setup->DO->Mode.
However be aware that DO can be set to external mode only if you have fw 1.0.500 and greater.
Replies 6
Anirban
Anirban Champion
Champion
2541
Hi Paul,
Posted: ‎2016-09-15 02:12 PM
Thanks, I had a feeling it was firmware related!! Cheers
Posted: ‎2016-09-15 05:04 PM
2541
Is it possible to upgrade the meter firmware for the PM3255?
Anirban
Anirban Champion
Champion
Posted: ‎2016-09-15 09:10 PM
As far as i know the answer is NO. Just confirm with tech support once.
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2016-12-16 11:06 PM
Hi Paul,
PM3255 firmware field upgrade feature will be available, only for the meters which will be manufactured from March 2017.
Kuzo
Kuzo
Explorer
Posted: ‎2021-08-28 02:40 AM
I have a power meter pm3255 with firmware v01.05.0 , I have enabled external control for digital outputs. I am failing to write to the meter getting response 3000.
