Continue
  • My Subscriptions
  • Events
Need CT Sensor suggestion for EM6400NG+
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Need CT Sensor suggestion for EM6400NG+
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Posted: ‎2022-10-04 06:30 AM
6
2649
Hello Everyone,
I am testing the EM6400NG+ energy meter for energy logging, In my setup, I used SCT010 20A:20mA CT and 10A variable load. To start I started testing with a single phase supply and I am able to see voltage measurement on the device, I tried many combination setting to get the measurement of current, but still device shows zero reading. I am confused as to do I am using the right CT sensor or the wrong configuration. Any help will be appreciated.
Thanks in Advance.
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-10-17 10:28 PM
2583
Hello @Anonymous user
EM6400NG+ supports only the Ip/5A or Ip/1A secondary current CTs, the SCT010 is low voltage output CT and the EM6400NG+ will be able to measure the output of SCT010 CT.
You can test with any METSECT5xxxxx CT references listed from the Powerlogic catalog.
https://download.schneider-electric.com/files?p_enDocType=Catalog&p_File_Name=PLSED309005EN_%28Web%2...
Ramasamy N
Ramasamy_N
Ramasamy_N Champion
Champion
Posted: ‎2022-10-18 03:18 AM . Last Modified: ‎2022-10-18 03:21 AM
2568
Hello Kirankumar,
Please confirm the CT secondary output current, if it 1A when the primary current 100A is applied. (no information available is web for this CT).
If yes, you can connect this CT with EM6400NG meter and configure the CT primary as 100A and secondary as 1A.
Please share the injected and measured current values if you see any difference.
Ramasamy N
Replies 6
Ramasamy_N
Ramasamy_N Champion
Champion
2583
Ramasamy N
Posted: ‎2022-10-18 03:02 AM
2571
Hello @Ramasamy_N
Thanks for the reply, you said I am proceeding to 1p/1A  to test it and below is the CT I found similar. Can you please confirm the same https://robu.in/product/yhdc-sct-024ts-100a-1a-split-core-current-transformer/?gclid=Cj0KCQjwnbmaBhD....
Thanks & Regards,
KISHANKUMAR J
Ramasamy_N
Ramasamy_N Champion
Champion
2568
Hello Kirankumar,
Ramasamy N
Posted: ‎2022-11-12 12:57 AM
Hii Ramasamy,
Thank you for your support and suggestions for the query, The configuration setting has been found on youtube, and for measurement results, I will share you in some time.
KISHANKUMAR J
sanjay16008
sanjay16008
Explorer
Posted: ‎2026-03-27 06:03 AM
571
How to communicate with PC of EM6400NG+ meter
Charles_Murison
Champion
Posted: ‎2026-03-30 09:36 AM
Hello @sanjay16008 ,
Please fere to user Manual
https://www.productinfo.schneider-electric.com/em6400ng/5af9a18446e0fb00011e3318/EM6400NG%20User%20M...
Charles
