Maximum number of PM5350 for Daisy chain?
Metering & Power Quality
  • EcoStruxure Power & Grid
  • Maximum number of PM5350 for Daisy chain?
Charles_Murison
Picard Charles_Murison Picard
526
Mehran_Mehrnia
Admiral Mehran_Mehrnia Admiral
138
Ramasamy_N
Captain Ramasamy_N Captain
115
Posted: ‎2013-10-15 09:11 PM
892
Real implementation will be great.
thanks
JamesAZZO
Sisko | EcoXpert Master JamesAZZO Sisko | EcoXpert Master
Posted: ‎2013-10-16 04:59 AM
A total of 15 on a relatively short run of RS-485 in our experience to keep Vista live diagrams loading completely in under 5 seconds.
jimbradley
jimbradley Schneider Alumni (Retired)
Posted: ‎2013-11-13 11:11 AM
James is correct from a systems performance point of view.  Indeed I would say for 5 second updates I'd go as low as 6 devices, depending somewhat on device type. Most of this is due to device communications latency and the PME comm architecture (multiple clients asking for different data from the same device) and not the RS-485 spec.  If the system does not require reasonably fast real time response then more devices can be on one line.
From a hardware specification point of view the RS-485 spec allows for 32 devices per loop and a wiring length of 4000' / 1000 m.
As one gets gets more devices and longer wiring lengths strict adherence to the spec is required, i.e. no stubs or T's or taps are permitted, the cabling must be designed to RS-485 (correct impedance) etc.
Jim
