Continue
  • My Subscriptions
  • Events
ION9000 CID Files for interfacing with IEC 61850 SCADA (non-Schnider)
Metering & Power Quality
  • EcoStruxure Power & Grid
  • ION9000 CID Files for interfacing with IEC 61850 SCADA (non-Schnider)
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
PowerLogic ION9000
Subhro_Roy
Subhro_Roy Explorer
Explorer
Posted: ‎2020-12-21 07:30 AM
5632
Dear Experts.
Need your help for Thai Oil Project.
The issue is related to ION9000 meter CID file integration with ABB system. For which seeking your support to get the solution from ION expert/R&D team.
The IEC 61850 SCADA is from ABB
  • We have supplied ION9000 meter for energy reading and communication through IEC61850 protocol integrated with ABB SCADA system.
  • For the integration purpose, we sent the appropriate meter CID file to PSS/ABB team for configuration. ION9000 meter CID files  come with “Attribute Level” mapping as default. Refer the attached  picture-1 as seen from CET580 tool.
  • We received the feedback from PSS/ABB is that they are not able to map the ION9000 CID files at “data‐attribute level” but only at “data‐object level”.  After importing ION9000 meter CID file into the IEC tool,  only “Data Attribute” is visible, which ABB cannot map into their system. Refer the picture-2 with highlight.
  • Further, we reconfigured the ION9000 meter CID files with “Data Object Level” configuration using CET850 tool. Now ABB  is able to configure in their IET tool based on “Data Object Level” mapping .
  • However, now we are unable to upload the file into ION9000 meter.
  • How can we upload the CID file with “Data Object Level” mapping to ION9000 meter? Or do we have any other way around to overcome this  issue?
  • Thumbnail of PowerLogic ION9000
    PowerLogic ION9000
View products (1)
  • ION9000
Charles_Murison
Champion
Posted: ‎2020-12-21 10:15 AM
2
5628
Hello @Subhro_Roy  (please update name from sesa)
The current firmware of the ION9000 meter is configured to require the data attribute level. To change this would require a feature request best submitted through your sales channels.
Charles
Replies 7
Charles_Murison
Champion
2
5628
Charles
Charles_Murison
Champion
Posted: ‎2021-01-11 09:57 AM . Last Modified: ‎2021-01-11 10:27 AM
3
5607
Do you have the the name of the end software SCADA system?
Charles
Subhro_Roy
Subhro_Roy Explorer
Explorer
Posted: ‎2021-01-11 07:27 PM
Hi Charles,
The SCADA is supplied by ABB - I will try to get the specific SCADA software from our Customers. Thanks for your support.
Hitachis
Hitachis
Explorer
Posted: ‎2023-02-27 07:25 AM
4559
good morning Charles
We have the same problem with the SIEMENS PCS7 software.
Charles_Murison
Champion
Posted: ‎2023-02-28 09:26 AM
Hello @Hitachis
regards,
Charles
HctorSantisteban
HctorSantisteban
Explorer
Posted: ‎2026-06-09 03:34 PM
891
Could you please share the contact of someone who can assist me with this configuration? I haven’t received any response from support via email regarding this matter so far.
Charles_Murison
Champion
Posted: ‎2026-06-10 11:18 AM
Hello @HctorSantisteban ,
Are you able to share your case number?
Charles
