How to get the current swell module in ION7650?
Metering & Power Quality
Send InviteCancel
2017-09-0501:10 AM
1. I want to know if the latest firmware (410?) and latest template for an ION7650 give the same possibilities as with the PM8000 regarding Current Swell/Sag with waveform recording.
I think it is possible if I add modules and make links between these and other modules. But of course I prefer to have a standard solution.
The screenhot below is from the PM8000:
I have an "old" test ION7650 with V371e. (PJ-0510A075-01)
I just found out that the latest firmware is V410.
I expect that I cannot use this one on my test ION7650, since for V401 there was V374 for the older ION7650 devices.
2. Which is the latest firmware for my test device?
3. Where can I find the standard template for each firmware? (Or at least for the latest firmware.)
The meter's current inputs could be monitored with the Sag/Swell module, but this is not implemented in any released template. Note also that some meters / FW revisions only support one Sag/Swell module.
