How to access the Phasor Viewer and Meter configuration reports on ION 8650C meters with ION Setup v3.0
Metering & Power Quality
Select a Country
  • EcoStruxure Power & Grid
  • How to access the Phasor Viewer and Meter configuration reports on ION 8650C meters with ION Setup v3.0
Charles_Murison
Charles_Murison Champion
566
Mehran_Mehrnia
Mehran_Mehrnia Champion
194
Ramasamy_N
Ramasamy_N Champion
115
ekourany_btupan
ekourany_btupan
Troubleshooter
Posted: ‎2013-09-27 04:34 PM . Last Modified: ‎2020-04-22 01:54 AM
1717
Hi guys. I am using ION SETUP Ver 3.0.12255.01
I have an ION 8650C meter with the following specs:
Reference: M8650 C0C0H6E1A0A
Meter FW Revesion: 1.4
Template: 8650C_FAC_V4.1.0.0.1
Default Template: 8000_FAC_V1.1.0
In this case in the Setup Assistant  left panel on the main screen neither the VERIFICATION or REPORTS tap appear..
Thus, cant find a way to get to the phasor viewer usually from the "wiring" tap on the the verification  screen or to the reports available from the setup assistant main screen
Is it the version of ION Setup I am using or the template or firmware revision of this meter??
  • ION Setup
Tags (5)
  • 8650c
  • an
  • and
  • configuration
  • finding
ekourany_btupan
ekourany_btupan
Troubleshooter
Posted: ‎2013-09-29 08:04 PM
Just downloaded the most recent version of ION SETUP v3.0 and solved the issue.
