Continue
  • My Subscriptions
  • Events
HDPM6000 UDP Port 47808 change to UDP Port 47807 for BACnet
Metering & Power Quality
  • EcoStruxure Power & Grid
  • HDPM6000 UDP Port 47808 change to UDP Port 47807 for BACnet
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
KimS
KimS Contributor
Contributor
Posted: ‎2024-02-20 10:42 AM . Last Modified: ‎2024-02-20 10:58 AM
1992
Customer is using BACnet with the HDPM6000.  How can I change the UDP Port 47808 to UDP Port 47807?
  • HDPM6000
KimS
KimS Contributor
Contributor
Posted: ‎2024-02-20 10:42 AM . Last Modified: ‎2024-02-20 10:59 AM
The HDPM6000 UDP port number for BACnet IP protocol will use only the default port 47808 and it cannot be changed at this time.
KimS
KimS Contributor
Contributor
