As per the latest catalog, there is a note for 0.2s class accuracy support for 3PH,4W configuration.
Wanted to check if the same ordering code of 0.2 can be used for the same.
Hi@Hitesh14 Yes, you are correct. That note is not accurate. For active energy, it's Class 0.2 as per IEC 62053-22 for a 3P4W system. The catalog is old one and needs to be corrected. Please refer to the latest user manual specification.
BR,
Akash
Hello @Jesus_Diaz ,
Do you know who would be able to answer the question about EM6400 meter?
Charles
Hi @Hitesh14,
Do you mean which commercial reference supports 0.2 for 3PH, 4W configuration?
According to the catalog, the commercial reference METSEEM6400NGRSCL2 will provide Class 0.2S active energy accuracy per IEC 62053-22 standard in 3PH, 4W configuration.
Best regards,
JD
as per the LOB responsible the note given in the catalog is a error.
BR,
Akash
