Continue
  • My Subscriptions
  • Events
AccuSine max cable length
Metering & Power Quality
  • EcoStruxure Power & Grid
  • AccuSine max cable length
Charles_Murison
Charles_Murison Champion
582
Mehran_Mehrnia
Mehran_Mehrnia Champion
216
Ramasamy_N
Ramasamy_N Champion
117
Szymon_Hochół
Szymon_Hochół Champion
Champion
Posted: ‎2018-11-23 03:02 AM . Last Modified: ‎2020-12-02 03:31 AM
1506
Hello Experts!
Is there any document that states maximum length of power cables for AccuSine?
The longer the cable, the higher it's impedance which (I'm guessing) can become a problem at certain point.
Any ideas?
Best regards,
Sz.
  • Power Quality
Remi_Bolduc
Remi_Bolduc Troubleshooter
Troubleshooter
Posted: ‎2019-01-07 08:15 AM
1
1503
There is no table that states the maximum cable lenght of power cables for AccuSine. Basically the local electrical code must be respected and you also have to make sure that you have enough cables to limit the voltage drop across the cable run, values of 3% to 5% voltage drop are normally used. The AccuSine itself has a +10%/-15% voltage input tolerence.
Remi_Bolduc
Troubleshooter
1
1503
Szymon_Hochół
Champion
Posted: ‎2019-01-14 11:41 PM
Thank you
