Selecting sensor values for a Map View's devices
Map view features
  • EcoStruxure IT Help Center
  • DCE Device and Map views
  • Map view features
  • Selecting sensor values for a Map View's devices
  • Mark as Read
  • Map View features
  • Map Settings
  • Customizing the device icons
  • Custom Label Settings
  • Creating a customized background in Map view
  • Button icons (Map View)
  • Add to Map
  • Map View features
  • Map Settings
  • Add to Map
EcoStruxure IT Support
Request Support
Back to Map view features
  • Mark as Read
Picard EcoStruxureIT
‎2019-11-20 06:13 AM
Use the Map Label Settings display to select an identifier to display for all devices and sensors in a Map View, and to select a sensor value to display on all devices on the map that report the sensor.
Use the Custom Label Settings display to select a custom identifier or sensor value to be displayed for a specific device in a map.
Selecting Map Label Settings for all devices in a map
You can select an identifier and a sensor value for all devices to display in a Map View, however, only devices that report that sensor will show its value.
  1. Select the right-click option, or the icon at the top of the Map View. Select the option.
  2. Check-mark the Show Identifier option, and select an identifier from the list.
  3. Make sure the Show Value option is check-marked.
  4. Select the sensor you want to use from the available sensor list.
Selecting Custom Label Settings for a selected device or set of devices
You can select a device or set of devices in a Map View, and select an identifier to display instead of the identifier set in the display. You must select one device at a time to also define a custom value to display for a specific sensor.
  1. Select the device or set of devices in the Map View.
  2. Select the right-click option, or the icon at the top of the Map View.
  3. Check-mark the Show Identifier option, and select the identifier you want the device or set of devices to display.
  4. When one device is selected, define the sensor value you want the device to display, by choosing one of the following options:
    • Select Display the value set in Map Settings if you want the selected device to use the settings defined in the Map Settings display.
    • Select Choose a specific sensor value, and select the sensor you want to use from the available sensor list, if you want the selected device to use a custom setting.
