Add to Map
Map view features
Send InviteCancel
Select the device groups, devices, and sensors to add to a map.
You select Edit Map, then select Add to Map from the right-click menu in a map. You use three tabs, Sensors, Devices, and Device Groups, to select the sensors, devices, or device groups you want to add to the map.
You can use the Search field to filter the list on each tab based on the text you type. Only the Boolean operators AND, OR, and NOT are supported.
You can select the Configure Columns icon on the Sensors and Devices tabs to identify the columns that appear in the display. You can click the column headers to sort the list in ascending or descending order.
The Unassigned group is automatically added to the map for the All Devices group. Any device group you create, and any device you add to a device group, is automatically added to the map for the selected device group. Sensors must be added to a map manually.
When all the device groups, devices, or sensors available for the selection are already added to the map, the list on the Sensors, Devices, or Device Group tabs is empty. When a device group, device, or sensor has not been added to the map, or has been removed from the map, it is listed on the appropriate tab, and can be added to the map later.
