Datasheets, install guides and other information on HID Electronic Access Control products
  • Datasheets, install guides and other information on HID Electronic Access Control products
  • sesa119747
    sesa119747
  • PaulFr
    PaulFr
  • CraigEl
    CraigEl
‎2018-09-10 05:06 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 12:19 AM
Where can I find datasheets, install guides and other documentation on the HID SmartID, iClass, HID Proximity and Indala Proximity cards and readers?
Andover Continuum, Field Devices, TAC INET
Electronic Access Control cards and readers for Continuum and I/Net products.
Additional product information from HID may be required that is not available on Schneider Electric's own websites.
Schneider Electric supply a subset of the full HID range of cards and readers and these are detailed in the Electronic Access Control Catalogue or see How to determine the part number for the card format required for part number information.
For HID product information this can be directly downloaded from the HID Global website. This contains  datasheets, installation guides, application notes, feature lists, brochures and other documentation. HID also have a "Knowledge Center" website that allows you to search for product information and help: HID Knowledge Base.
Information on the specific ranges can be obtained from the following links:
SmartID:
  • SmartID Cards
iClass:
  • iClass Readers
  • iClass SE Readers
  • iClass Cards
HID Prox:
  • HID Proximity Readers
  • HID Proximity Cards
Indala Prox:
  • Indala Proximity Readers
  • Indala Proximity Cards
Labels (3)
  • Field Devices
  • TAC INET
  • 6643
