What is the difference between 1st and 2nd Generation X Drivers
  • What is the difference between 1st and 2nd Generation X Drivers
  • Cody_Failinger
    Cody_Failinger
  • PaulFr
    PaulFr
  • sesa119747
    sesa119747
‎2018-09-07 11:55 PM
Some X Drivers on the Third Party Interface datasheet are classed as 1st Generation and others are 2nd Generation, which drivers should I use?
Andover Continuum
All X Drivers
Any controller with XDrivers enabled on a Comm port.
Sometimes the incorrect file is being used on a controller and this will stop the X Driver from working correctly.
You can only use a 1st Generation X Driver on a 1st Generation controller and a 2nd Generation X Driver on a 2nd generation controller.
- 1st Generation controllers are: CX9200, CX9400, CX9900, CX9940, CMX9924
- 2nd Generation controllers are: Netcontroller II (CX9680), bCX1 (4040 or 9640), ACX II (5740, 5720)
Download the Third Party Interface datasheet
Note: Not all X Drivers are available for both generations of controllers, consult the above datasheet for availability.
  • 5136
100% helpful (1/1)
