Web Service addition SOAP Web Service
  • Web Service addition SOAP Web Service
  • CraigEl
    CraigEl
  • sesa139513
    sesa139513
‎2018-09-10 01:26 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 03:48 AM
How to add Web Service and create SOAP Web Service with Graphic
StruxureWare Building Operation site with release 1.2 or later
What are Web Services and how to add to my existing StruxureWare Building Operation site.
  1. How to add SOAP Web Service files and how to add to a project or site
  2. How to create values from SOAP Web Service Files
  3. How to add values to graphic that uses the values from SOAP Web Service
Wikipedia: A Web Service is a method of communication between two electronic devices over the web (internet). W3C: A "Web Service" as "a software system designed to support interoperable machine-to-machine interaction over a network."
Web Services:
  1. are hardware, programming language, and operating system independent
  2. Applications written in different programming languages and running on different platforms can seamlessly exchange data over intranet or the internet using Web Services
  3. Web Service interfaces are supported in both the AS and ES(does not support connection over a ProxyServer)
  4. Like BACnet, Lon, and Modbus, you can create a Web Service interface.
  • EWS Interface - EcoStruxure Web Services
  • Script Web Service - Generic Consume via Script (Web Service addition Script Web Service)
  • Simple XML Web Service - Rest Generic Consume via Binding Tool (Web Service addition Simple XML Web Service)
  • SOAP Web Service - SOAP Generic Consume via Binding Tool
This article explains adding Sunrise and Sunset for a particular location data using SOAP Web Service:
  1. Select New > Interface > Web Service > SOAP Web Service
  2. Next Paste the URL which has the SOAP Web Service feature ((to find sunset/sunrise for your area, Google WSDL data) and location coordinates
  3. Get Operations button pulls in the data. Select Next  which shows the values and times and then select Create
  4. Create values by highlighting SOAP Web Service then File > New > Value
  5. Choose Next and highlight the specific for the values then select Create
  6. Here are the SOAP Web Service sunrise/sunset values
  7. If desired, Bind those values to a graphic
  8. Lastly for SOAP Web Service a graphic is created and the values which come from the SOAP Web Service are place on the page
  • 11450
