The Xenta Repeater Provides Signal Restoration and Conditioning on LON Networks
  • The Xenta Repeater Provides Signal Restoration and Conditioning on LON Networks
  • MikaelKrantz
    MikaelKrantz
  • LeeCravens
    LeeCravens
‎2018-09-10 12:14 AM
Last Updated: Administrator CraigEl Administrator ‎2025-11-02 06:15 PM
LON networks may experience communication issues due to excessive physical length or a high number of connected devices. The Xenta Repeater helps mitigate these issues by restoring and conditioning signals, enabling longer network spans and supporting more devices.
TAC Vista
  • Vista Lon Networks
  • Xenta Repeaters (Part # 007309120)
LON communication failures often stem from:
  • Exceeding recommended cable lengths
  • Overloading the network with too many devices
The Xenta Repeater:
  • Uses a standard Xenta 400 base
  • Splits a LON channel into two segments
  • Connects one segment to COM 1 terminals, and the other to COM 2 terminals
🔍 Note:
  • A LON channel is a section of the network separated by a router.
  • A segment is a portion of a channel divided using a repeater.
📏 Cable Length Guidelines
Cable Type Max Bus Length (Doubly Terminated) Max Node-to-Node (Singly Terminated) Max Segment Length (Singly Terminated)
Belden 85102 2,700 m / 8,858 ft 500 m / 1,640 ft 500 m / 1,640 ft
Belden 8471 2,700 m / 8,858 ft 400 m / 1,312 ft 500 m / 1,640 ft
UL Level IV 22AWG 1,400 m / 4,593 ft 400 m / 1,312 ft 500 m / 1,640 ft
Siemens J-Y(st)Y 900 m / 2,953 ft 320 m / 1,050 ft 500 m / 1,640 ft
TIA568A Cat.5 900 m / 2,953 ft 250 m / 820 ft 450 m / 1,476 ft
📌 Design Rules
  • Max 128 devices per LON channel
  • Max 64 devices per segment
  • Up to 2 repeaters per channel (max 3 segments)
  • If no router is used, only 64 devices allowed (single segment)
  • Recommended: ≤ 50 devices per segment for flexibility during installation
🔄 How It Works
The Xenta Repeater contains:
  • Two internally connected LON transceivers
  • Transient suppression circuits
It:
  • Reads LON packets from one segment
  • Re-broadcasts them to the next segment
  • Filters out noise, ensuring clean signal transmission
Unlike simple amplifiers, it does not amplify noise, resulting in strong, noise-free communication across segments.
Tags (2)
  • 5656
  • MikaelKrantz25
100% helpful (1/1)
