TAC ToolPack plug-ins are not showing up
  • TAC ToolPack plug-ins are not showing up
  • CraigEl
    CraigEl
  • Anonymous user
‎2018-09-07 04:09 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 10:00 PM
TAC ToolPack plug-ins (eg. STR 350 plug-in) do not show up
TAC Vista
  • TAC Vista 5.1.4, 5.1.5, 5.1.6
  • Windows 7, Windows Server 2008, Visio 2010
  • TAC System Plug-in
  • TAC Device Plug-in
  • TAC Zbuilder
  • TAC Xenta 100 Plug-in
  • TAC Xenta 102-AX Plug-in
  • STR 350 Plug-in
Not all plug-ins in the TAC ToolPack can run on Windows 7, Windows 2008 or Visio 2010.
When installing TAC ToolPack on these operating systems only the supported plug-ins will be installed:
  • TAC Zbuilder
If the desired plug-in is missing, configuration of your controller will need to be done manually in NL220, Lonmaker, or Vista.
Read details about manually setup STR 350/351 in STR 350/351 manually setup without plug-in (nciOption1 and nciOption2).
Tags (2)
  • 4331
  • thermostat
