Stem heater for Forta actuator
  • Stem heater for Forta actuator
  • PaulFr
    PaulFr
  • SESA150559
    SESA150559
  • CraigEl
    CraigEl
‎2018-09-06 12:28 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 10:26 PM
There are a few different stem heaters to choose from.
Field Devices
  • 8800108000
  • 8800109000
  • 8800110000
  • 8800112000
  • Stem heater
  • Yoke heater
Depending on application, there are a few different stem (yoke) heaters to choose between for the Forta actuators.
When Forta series actuator is used with a Venta valve, stem heater part no 8800108000 should be used when media temp is 0°C to -20°C.
Note: This stem heater is not compatible with the M700 actuator.
  • If used with V321 DN65-100, stem heater 8800110000 should be used.
  • If used with V222 DN65-100, stem heater 8800112000 should be used.
  • In other applications, yoke heater part no 8800109000 for Forta should be used. Capacity for the yoke heater is: Ambient temp  down to -10°C or media temp down to -8°C
For more on stem heaters, see Stem heater for V222/V292.
  • Field Devices
  • 7856
