What port numbers are used by the Sigma system?
  • What port numbers are used by the Sigma system?
  • sesa125819
    sesa125819
‎2018-09-06 12:30 PM
What Port numbers are used by the Sigma system?
Satchwell Sigma
  • Ethernet communications
  • Ports
  • Port
  • TCP
  • UDP
Known port numbers should be set as exemptions in the system firewall.
Sigma server to Sigma NNN / controller communications - User Datagram Protocol (UDP) uses port 49152.
Sigma server to Sigma client communications - Transmission Control Protocol (TCP) uses ports 3614 and 8080.
Sigma Web client communications - Transmission Control Protocol (TCP) uses ports 80 and 8080, but also uses port 3614.
  • Satchwell BAS & Sigma
Tags (6)
  • 7636
  • communications
  • port
  • ports
  • tcp
  • udp
100% helpful (1/1)
