Send to controller fails with "Not enough memory" error in Distribution View
  • Send to controller fails with "Not enough memory" error in Distribution View
  • AdamSteele
    AdamSteele
‎2018-09-06 02:02 PM
Unable to reload entire database using "Send to Controller" option. The error "Not enough memory" is seen in Distribution View when trying to reload some objects.
Andover Continuum
  • Continuum
  • b3 Series Controllers
  • i2 Series Controllers
Data is corrupt in controller Database or individual points such as Infinity Programs have become corrupt and are unable to be reloaded to the controller.
Clear the database in the controller and retry a "Send to Controller" as follows:
  1. Open the Device object of the i2 or b3 controller.
  2. Go to the "Runtime" tab.
  3. Press the "Reset" button to reset the controller and clear its memory.
  4. Retry "Send to Controller".
  • 4755
100% helpful (3/3)
