SQL Host not passing data to Xenta 527 Web Server
  • SQL Host not passing data to Xenta 527 Web Server
  • Cody_Failinger
    Cody_Failinger
  • Derrick_Ratliff
    Derrick_Ratliff
‎2018-09-06 01:46 PM
TAC INET, TAC Vista
I/NET
527 Web Server
When defining the Host for the primary SQL server, you have options of 1-250. When using a Web Server to send this information to a Vista System you must define the primary SQL server with a Host number less than 63.
  1. In I/NET configuration, define the primary SQL server's Host number between 1 and 63
  2. Restart the I/O server
  3. Connect to each Xenta 527 Web Server on site and modify change the SQL Host # to the host number assigned in step 1
  4. Restart each 527
Labels (2)
  • TAC INET
Tags (3)
  • 5290
  • SQL Host
  • Xenta 527 Web Server
