Reset Instructions for 1200 Series SCU
  • Reset Instructions for 1200 Series SCU
  • Cody_Failinger
    Cody_Failinger
  • sesa139513
    sesa139513
  • SESA128071
    SESA128071
‎2018-09-07 12:15 AM
Last Updated: Administrator DavidFisher Administrator ‎2020-10-22 06:31 AM
TAC INET
  • SCU 1200 series controllers
  • I/NET
Need to restart SCU, perhaps after a reload of firmware or dip switch settings
Follow the written instruction carefully.
Reset Instructions:
  1. Locate the 3-pin connector labeled P610 and the reset push button switch. Refer to the above diagram.
  2. Momentarily short P610 pins 1 and 2 while simultaneously pressing the reset push button switch.
    (Note: P610 pins 1 and 2 are the pins located nearest the dip switch.)
  3. Re-download the proper BIN file to the SCU.
  • TAC INET
  • 2013
100% helpful (1/1)
